Oil sump -> Clutch Housing Torque Specs?
Old 05-17-2018, 10:28 AM
Fellblade's Avatar
Default Oil sump -> Clutch Housing Torque Specs?
Hey folks, I was wondering if anyone could point me at the torque specs for the 14mm bolts used to connect the sump to the clutch housing?
I've checked the Torque Specs thread, but I wanted to double check which values I should be looking for; I've guessed that it's:
Transmission Bellhousing Bolts (lower small x 2) - 33
Transmission Bellhousing Bolts (lower large x 2) - 47
Because I couldn't see anything closer. Any advice appreciated!
Old 05-17-2018, 11:45 AM
flanders's Avatar
It's 33 lb-ft for those two smaller M10 (14mm head) bolts.
Old 05-17-2018, 01:35 PM
Fellblade's Avatar
Thank you sir! 45Nm for any metric folks finding this thread in the future
Gotpepsi
10-24-2013 08:58 AM
S2Kyle01
04-05-2007 03:22 PM
marshallhunting
05-01-2006 06:09 AM
Quick Reply: Oil sump -> Clutch Housing Torque Specs?
