Help new AP2 owner VSA AND TRIANGLE (!) lights on
#21
Well got call this morning, they told me my side engine mount is bad and I should go ahead and replace all of them. Plus rotors are warped and a wheel is bent. Rotors are fine as didn’t notice anything when braking and a have not noticed a rear tire bent as all the shaking was from front. SO I ask should I replace all the engine mounts like they are telling me I need to or just doing the side will be fine? In all my cars I have never had to replaced an engine mount unless doing engine swaps. Thanks for any insight.
#22
However replacing the engine mounts with OEM units will leave them susceptible to tearing again. There are aftermarket solutions that are more robust.
#23
Good to know. I would like to do some track days with my car and read on here people tend to like the Megan Racing replacement mounts. I’m wondering if I should look to go that way. I found a set for $310.
#24
Okay sorry have not been active as I have been traveling for work and Christmas. I got new engine mounts and replaced both with Megan racing ones even though only one was broken. The job was actually pretty straightforward.
I started driving the car to do some errands locally and having fun with the rpm range, everything seemed good until randomly the front started to shake again. I was really confused no lights came on tires and wheels are good as I even tried another set of s2000 wheels/tires.
So im really confused now. I feel like it’s almost something electrical as it randomly happens and when it does it’s constant from 0-70mph and every gear. BUT whenever I shit the car off even just for 1 minute and start to drive it’s good to go like there was never a problem. Again no lights are coming on and happens with any wheel and tire combo. IF ANYONE has had a similar situation please let me know what you did to fix it. I really want to try to get some track days in this upcoming season but not comfortable with this randomly happening. Thank you for any and all advice/help.
#25
where are you located? when does the vibration happen? under load? letting off? steady driving?
#26
I’m located in Dayton Ohio. And once it starts it’s constant does not go away unless I pull over shut the car off for like 2-3 minutes and then it’s seems to be good until it happens again.
FitzyS2k
02-22-2010 08:19 PM
