How to Clean IAC Valve
#22
Originally Posted by itlynstalyn,Feb 29 2008, 10:19 PM
when i push the clutch in to just idle to a stop sign or light, the revs die really quickly toward the end before it hits idle. dirty iac?
#24
You can spray the TB too...but unless you take the TB off, it won't clean the part that really needs it. On the backside of the TB there is a small passage that takes air to the MAP. That air passage can get carbon build up too. The only way to get at it is by pulling the TB off. Be prepared with either a new gasket or some gasket material to make a new one...when you pull the TB is is very hard not to mess up the gasket.
#25
This combined with a map whack and ECU reset fixed my low idle upon clutch depression in a test run of 20 stops.
I will find out tomorrow if it made a real difference, but it was nice not seeing my engine catch itself =)
Thanks.
Thanks.
#26
Yup! I just got finished doing the IAC clean up and ran the car for a bit and it seems to be responding fine to throttle depression and clutch.... Gonna reset the ECU and BAMB!!!!
#27
I started experiencing some mild (over a week period) and then extreme unstable bogging, jerking, loss of power in the lower rpm ranges (2-3k), and unstable idling. The car was unreliable, unsafe, and a bitch to drive. No CEL. A half a tank of gas. Fresh plugs, oil and filter, and new air filter. No abnormal noises or fluid levels.
I searched through all the threads.
Replaced air filter and peeked down the intake. It was clean.
I cleaned the MAP channel. https://www.s2ki.com/forums/index.php?showtopic=515674 It was fine, no blockage.
So I took on the IACV. Removed the cannon plug, coolant hoses, unbolted the IAC (Honda calls it a VALVE ASSY, ROTARY AIR CONTROL), removed, cleaned, inspected and reinstalled the valve.
That was three days ago. The car is running the way it used to, so far, so good.
#28
Did you reset the ECU? Some say it help start off fresh so give it a try and see what happens.... GL
#29
No ECU reset.
I did check the Volts and Ohms of the TPS from this thread - https://www.s2ki.com/forums/index.ph...=478799&st=100 - They were fine, as well.
If this problem reoccurs I'll buy and install a new IAC and if the resaults are favorable, I'll post up.
#30
The test drive put a on my face.
Still have not reset the ECU.
