I am going to have my engine out. Anything I should replace?
I am going to have the engine and transmission out of my s2k and I was wondering if there are things you would recommend replacing while they are out of the car. What seals are leak prone, etc??
The oil leak points on this engine are, valve cover gasket, spark plug tube seals, timing gear o-ring, timing case, oil pan, TCT, rear main seal and Vtec solenoid.
Crank end float check and replace thrust bearing if needed.
what others said
- check your starter out
- maybe rebuild the alternator rectifier depending on your milage, since its out and easily accessible
- check the ac compressor and clutch
- bearing replacement on serpentine components dependent on milage
The story so far=so maybe get another engine..
https://www.s2ki.com/forums/s2000-un...-then-1187483/
@soulicious I have noticed you have been following my posts and woes of bad machine shops. Thanks for your comments.
I called inline pro today. The price for sleeving, boring, forged internals is only 1000-2000 dollars less than a full jdm swap with jdm TRANNY, and alternator, water pump, etc. So that is the reason why I might just get a jdm full swap.
I know that it kind of seems like spending my way out of the problem, but there may be other unforseen issues with the previously screwed over engine. For example, the head was pretty warped, and even though the head is "fully rebuildable", I don't want my cams to seize up like this guy. And a million other things. I am still deciding. This is off topic for this thread, but I will update you guys in my other thread about the engine issues.
