I need a good mechanic in the Dallas /Fort Worth Area
I have a S2000 2001 model with 37,000 miles. I was down shifting to 4th gear going about 65 miles per hour when the engine red lined and started to miss and loose power. 1 minutes later I pulled off the freeway and check the oil and water they were ok. The car was hard to start and had a miss when it did start. I check the gauges and everything was ok. later the engine lit came on. Has anybody had a similiar experience? I have an extended warranty and they are not willing to authorize the cost of breaking down the engine, and probably the expense to repair the engine( they are thinking I have a bent valvle on the #4 cylinder). Just to teardown the engine will cost $600.00. Do I have any recourse? It I have to pay for the repair costs are there any good mechanics that can put my car back together without cost me a small fortune. Thanks for the input Tommy D 7/1/03 Update I have talked to the Honda people and they are talking about $5,500.00 for repairing the engine, how much will a new engine cost. Where can I find one, and if I have to repair the engine can I do some upgrades? Please help :eek2: |
Sounds like an obvious case of a misshift from 5th to 2nd, but you must have been going over 65 MPH.
I saw a thread from someone in Austin that might be selling a used engine. |
If your car is in pieces, oil is leaking out of every hole in your engine, smoke is billowing in the exhaust, and Alamo wanted to fix your car for $2, I would still recommend that you didn't go. From personal experience, Alamo messed up 2 of my friends Turbo Preludes, and if you need more reasons to not go to their shop, go check the NTPOG shop reviews, and you'd understand why.
Jason |
Have you tried Jotech? Is that far from you?
