ignition help
my tumblers in the ignition broke (key wouldnt turn anymore) so i picked up a ignition lock cylinder with matching key from a parted s2000.
i swapped the ignition, the car would crank but would not turn over Is this something that has to do with the immobilizer? would i need to get this reprogrammed? any help would be great thanks |
Yes, you'll need your ECU reprogrammed at the dealer to accept the new key that's equipped with an immobilizer.
Check with your local honda dealer for the cost. |
try holding the old key next to the new key and see if it will run then
Yah figured it would be needed to be programmed.
Tried holding the old key next to be but still wouldnt turn over |
| All times are GMT -8. The time now is 05:47 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
