Installed ACT PP + OEM everything else. Something's not right. Please help
Installed ACT PP + OEM everything else. Something's not right. EDIT: success!
The original clutch in my 07 had been making tons of rattling noise lately so decided it's time for a clutch job.
Over the weekend friend and I installed the same combo that's been recommended here over any over again: ACT pressure plate (H021), OEM friction plate, OEM AP1 flywheel, OEM throw out bearing and also OEM clutch master cylinder. Install went smoothly but right away these issues below caught my attention after starting the car:
Any advice would be appreciated. Thanks!
- There seems to be a constant noise coming from bell housing when the clutch pedal is in the up position and goes away when pedal is depressed. It's a "rotating" sound that is audible (although faint) outside the car over the sound of cold start engine. Inside the car it is much more noticeable with windows up and without the shifter boot. With shifter boot installed it is definitely quieter but can still be heard.
Here is a video from inside of the car looking into the shifter (in neutral) without boot:
- The piston on the clutch slave cylinder is constantly pushed against the shifter fork when clutch pedal is in the up position.
- Clutch engagement point is about 1/2" to 1" from the floor.
My car makes a somewhat similar noise depending on the clutch being engaged or not but yours does sound a little worse at least on video. What you're saying about the slave cylinder piston and clutch fork sounds normal to me. It should also have pressure against the fork. Lastly, you probably just need to bleed your clutch system better. It can take a bit of time. I just replaced my cmc and had to bleed it a second time.
You may just be hearing gear noise.
#2 is normal. Virtually every hydraulic clutch system has a constantly running release bearing. There is a spring inside the slave cylinder that puts a small preload on the fork at all times. The release bearing is always in contact and thus always spins. This is also how the "self adjusting" feature on the clutch works.
Your engagement issue likely has something to do with bleeding or the initial Master Cylinder Preload adjustment
Thanks for the replies, I'll rebleed the MC again.
About the noise, that was what caught me off guard as it's abnormally loud. Could it be the throw-out/release bearing is bad?
The only thing not put back is the shifter tunnel trim panel (cut holder, arm rest) but I put all the underneath layers on, rubber boot that covers the 3 shifter bolts, foam that surrounds the shifter in between tunnel sheet metal, round rubber boot with white plastic ring and it can still be heard inside the car. It can also be heard outside on a cold started engine with HFC + Fujitsubo Legalis.
My friend whom has done multiple clutches also noticed the sound on first engine start.
