Installed ACT PP + OEM everything else. Something's not right. Please help
Yes. transmission fluid was just done 7k miles (1.5 years ago), didn't open the tranny to do this clutch job.
Seems like the general consensus is that this sounds normal. Perhaps I'm just paranoid because I seem to remember my stock clutch was silent.
thanks!
thanks!
Functionally, I don't think it hurts anything, just annoying. My car did the same thing until I changed my clutch at 70k miles. Pretty much same set up as you. I noticed that the springs on the old friction disk were pretty loose inside the cages so that could be the cause of the sound.
Everything that went in for this install are brand new, that's why I'm a little paranoid after hearing this (new to me) sound.
Just want to give my exp for reference. I have the exact same setup in mine. There was no chatter and honestly your setup now sounded like my stock setup before. Also, my clutch engagement point remained just about exactly the same as before basically 2/3rds of the way up but with a very slightly stiffer pedal feel.
I also think it is very important in the sequence you tighten down the clutch bolts. Also not to overtighten them making sure by using a torque wrench uniformly tightening all bolts to the same spec in a step by step process (first to 5, then 10, so on and so forth).
Seems like the general consensus is that a little bit of sound from throw out bearing is normal, that gives me all the confidence I needed.
I re-bleed the clutch, it does feel better now, also adjusted the clutch pedal travel via both where it connects to the clutch master cylinder and the up position end stop. Pedal has a little bit of slop before pushing against the CMC but the clutch engagement point is still pretty low, about 3/4th of the pedal travel, is there anyway to get it adjusted up to around 1/4th of pedal travel besides the two nuts mentioned above? I'm already running out of adjustment range on the master cylinder rod thread.
Thanks again
sounds alittle louder than normal but it does sound normal. I had the same problem with my car, I gave up and swapped the pressure plate(mugen) and dropped all the noise. ACT while performs well but the noise got to me...
