Leak-down & Compression test
Old Sep 2, 2005 | 08:01 AM
jason4207's Avatar
Default Leak-down & Compression test
I bought my '02 S2000 used w/ 39k on it. I wish I had done a leak-down & compression test before I bought it, but I didn't even know it was important till after joining this forum. I want to get the tests done, but I wonder if I get a bad result, what will I be able to do about it? Will there be a fix besides replacing the block and or pistons/rings? It almost seems futile to pay for the tests if you can't do anything to fix it.
Old Sep 2, 2005 | 08:06 AM
Logik's Avatar
Compression test tells you how much pressure your cylinders are holding, and the leakdown tells you where the compression mixture is escaping.
Where can it escape? Piston rings, valves, valve stem seals. So a leakdown test can tell you what exactly needs replacing, so no you do not always need to replace your pistons/block. In fact you never have to replace your pistons/block, just maybe the piston rings and a re-hone of the walls.
Old Sep 2, 2005 | 08:26 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Leakdown will not tell you WHERE the leak is going directly.
Valve stem seals will not be a cause of a cyl pressure leak.
The cylinders are FRM and not honeable.
Old Sep 2, 2005 | 08:28 AM
jason4207's Avatar
Billman250,
So what can I do if I have a leak?
Old Sep 2, 2005 | 10:53 PM
Slows2k's Avatar
Rebuild or replace the motor.
Old Sep 2, 2005 | 11:35 PM
jason4207's Avatar
That's what I thought, so getting the test done is futile unless you have thousands to burn.
That sucks
Old Sep 3, 2005 | 04:45 AM
FF2Skip's Avatar
This is great news! I don't have to replace my piston or block!
And Jason, I wouldn't go so far as to say it's useless. Some smaller problems left unattended can lead to bigger problems.
Old Sep 3, 2005 | 08:30 AM
Billman250's Avatar
Top Answer: 1
Low compression could be a tight valve. But out of 100+ s2k's, I've yet to find a single tight valve. This would likely only come into play if the valve clearence was improperly set.
Old Sep 4, 2005 | 02:19 PM
C6400hp's Avatar
IIRC honing the cylinders is possible but, it takes special equipment to do it...
Old Sep 5, 2005 | 07:29 AM
Slows2k's Avatar
The FRM bores have very specific honing procedures. They are difficult enough to hone, it's not worth the risk of trying. The only oversize piston available are .5mm oversize. Most scuffed bores will require more than .5mm to correct.
MikeGs2k
Engine Swaps
Mar 21, 2017 04:10 PM
Backmarker
Sep 21, 2016 03:59 PM
Stealth_SUX_
Jun 25, 2008 02:38 AM
FormerH22a4
May 31, 2005 08:23 AM
