LIFTERS?
Old Jan 18, 2007 | 03:14 PM
CaymanS2k's Avatar
Thumbs up LIFTERS?
(UPDATED) I wonder if one of the lifters could be stuck and making this knocking noise. sounds like it is from the back of head. that's what a few people are saying.
(PREVIOUSLY) ok guys, got the car started. Thanks to BILLMAN... everything in the head is brand new basically including the head...changed the chain, tensioner, and autotensioner, and it still is making a knocking noise in the head. if the autotensioner didnt have the pin in it before puttin it in, could that be a reason why? this is getting so fustrated now, i might buy a new engine soon the way this is going. any help on this one?
thanks for all your help.
Mike
webster.me@gmail.com
Old Jan 18, 2007 | 04:10 PM
FISH22's Avatar
i wouldnt think that a bad or faulty tensioner would cause a knocking sound, more like a ticking sound. are you sure its not coming from the block. possibly a rod/bearing.
Old Jan 18, 2007 | 04:18 PM
CaymanS2k's Avatar
The machanic said it wasnt the bearings when it first came in, and its not as loud as it was before i replaced the head, cams, chain, tensioner, autotensioner. And now when i give it a rev, it shuts off when it goes back to idle. ughh.. i wish we had a good honda machanic here on the island
Old Jan 19, 2007 | 11:11 AM
CaymanS2k's Avatar
could it be lifters, maybe one stuck that could be making this knocking? i believe thats the only things left that i didnt put in new.
Old Jan 19, 2007 | 12:08 PM
Stratocaster's Avatar
Post a sound clip.
Old Jan 19, 2007 | 12:15 PM
CaymanS2k's Avatar
Originally Posted by Stratocaster,Jan 19 2007, 01:08 PM
Post a sound clip.
i dont have anything to do that with...kinda sounds like a rod knock, but its not that loud..but its not the bottom end.
Old Jan 19, 2007 | 12:31 PM
90crvtec's Avatar
You have an early year AP1 and with the noise described as coming from the rear of the motor, I'd have to guess a bore is scuffed? Does your car have the updated oil jet bolts?
To be perfectly frank I think it'd be really hard to miss a scuffed bore since the head was already off of the car. But then again, the guys that put it back together couldn't get it timed right either. So who knows....
Old Jan 19, 2007 | 02:23 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There are no lifters in the s2k.
Putting the tensioner in without the pin is a surefire way to break something, mainly the chain guides and chain. Most people who try to put the tensioner in without the pin get about 200 feet then break the chain. You may have a broken guide.
Old Jan 19, 2007 | 02:45 PM
CaymanS2k's Avatar
its not the tensioner. the machanic thinks the valves need to be a little tighter now. I'm going to check the autotensioner again tonite, and maybe try to take it out and put the old on in.
Old Jan 19, 2007 | 03:18 PM
Billman250's Avatar
Top Answer: 1
Valves should be .008-.010 for intake, .010-.011 for exhaust.
Even if they are out to .013, they will not make substantial noise. Ask him what they were set at during the rebuild.
sleepysnake
Mar 13, 2016 10:14 AM
jyeung528
Dec 24, 2013 05:20 PM
Reaper31292
Mar 1, 2012 01:04 PM
kill
Mar 4, 2007 08:04 PM
JTNY
Nov 20, 2006 07:29 AM
