loud clunk when under hard turning.
ikrath, what was the problem? What needed replacing? I think i have the exact same problem. I hear a "pop......pop....pop..pop.pop" noise only when i corner extremely hard (tires limit). Everybody keep saying to retorque my axle nut, but that's not it. Can you help me? Thanks.
need some help here iv searched high and low and can't find a direction now. My car (2001 s2000 78k miles) now sounds like someone's beating on a large drum also. Going into first while turning (doesn't seam to do it going straight) its a loud clunking coming from the rear I can feel it under my seat. Iv tried the Axel nut fix / tsb. No luck there but damn were they loose. Still clunking like crazy on sharp turns mostly first sometimes second. Someone said to hold the clutch in longer tried that. Someone said when you shift into gear to give it a couple seconds before releasing the clutch tried that. Tried keeping the rpms around 3/4k but still wants to clunk clunk clunk on sharp turns at low speeds / sharper turns. Idk what to think iv flushed the differential and saw nothing alarming. Everything seams nice and tight under there iv checked 3 times now. Nothing seams alarming what could it be
Please excuse the novel SOMEONE HELP PLEASSSSSSE
