Low compression along all cylinders
Typically how long does a leak down test take?
My experience is that compression tests can be all over the lot. I think the important thing is that you do it a few times under the same conditions in a consistent fashion.
Something even as silly as a weak battery can give you low readings.
When using cheap gauges, it is much more important that the compression is even across the board. I've seen some gauges read hilariously low (like 130 when they were supposed to read 180 on a quality gauge).
Low compression
I also have low compression in all 4 cylinders but my numbers are way worse. 1-60, 2-55, 3-60, 4-65. I did each cylinder twice when I did the compression test. The car has lost a noticeable amount of power (obviously) but it still runs fine. Anyone have any ideas on what could cause such low compression??
