Low oil on dipstick.... how bad?
#31
EXACTLY!!!
...and hearing that cars have had engine fires and bearing failures due to filter coming loose should make an even stronger emphasis.
This was my experience. I read here how important it was to use oem filter. Swapped the *gasp* Fram filter that my car had when I got it asap. But didn't know about the tightening procedure, and who reads instructions on something you've done hundreds of times before. But as soon as I heard there was a specific procedure, I diligently followed it.
I bet if Honda made the filter look veey different from all other oil filters, we wouldn't be having these conversations...
Mr.Matchbox (05-03-2019)
#33
I really want to see the after picture of that meme
#35
#37
i'm curious, the typical screw on oil filter that can be hand tightened, those instructions also call for 7/8 turn - are these typical filters able to be turned 7/8 by hand? meaning the s2000 oem filter is different in that it is not able to be turned 7/8 by hand?
#38
I dont care, i allways use a torque wrench, because i never get the first starting point "gasket contact to engine block" right. I am clumsy at this task. After years of "was almost loose... Damned, was to tight.." when changng the filter again i found that i get good, consistent results when using a torque wrench. Oil the seal, torque it down according to the specs, done.
As a side note, Suzuki Motorcycle Oil filters have a O-Ring gasket and call for 2 complete turns. If done correct you feel metal-to-metal contact at the end.
#39
You need to first get past that ring, contact the rubber gasket, and THEN go 7/8 turn...which roughly equates to 18LB-FT.
Doing this causes the ring to deform and seal.
Its not 7/8 turn from initial contact.
You'd have to be an actual GD, MF'ing silverback gorilla like my man Harambe (RIP) to do this.
Try this:
Grab a torque wrench and set it to 18LB-FT. Put it on a bolt and tighten til it clicks. Now imagine trying to turn a slippery, ~3.25" diameter cylindrical object to that spec while reaching into an engine bay.
Now imagine being a gorilla.
Put those two thoughts together.
Then you have the full picture.
rizzllzahid (02-09-2021)
