Low oil on dipstick.... how bad?
#41
I don't have a fumoto...but I do always torque from the top. No issues even with my sandwich plate that spaces the filter out. I do unplug the VTEC solenoid to avoid damaging it by mistake.
#43
The S2000 filter uses a metal crush ring.
You need to first get past that ring, contact the rubber gasket, and THEN go 7/8 turn...which roughly equates to 18LB-FT.
Doing this causes the ring to deform and seal.
Its not 7/8 turn from initial contact.
You'd have to be an actual GD, MF'ing silverback gorilla like my man Harambe (RIP) to do this.
Try this:
Grab a torque wrench and set it to 18LB-FT. Put it on a bolt and tighten til it clicks. Now imagine trying to turn a slippery, ~3.25" diameter cylindrical object to that spec while reaching into an engine bay.
Now imagine being a gorilla.
Put those two thoughts together.
Then you have the full picture.
Try this:
typical non-s2000 filter, 7/8 turn does not equal anywhere close to 18 ft/lb and is achievable by hand.
is that what you're confirming?
#44
Why are we making this hard?
I say again the torque spec is 16 lbf-ft (sixteen) or 22 N-m. Honda specifies a special tool for this filter which has a fitting for a wrench to remove it and a torque wrench to install it. If you want that tool order 07912-6110001 for about $45 (!) or get the
Advance Auto Parts version
-- Chuck
-- Chuck
#46
- The S2000 filter is not 7/8 turn from initial contact. Its from GASKET contact.
- There is no way to get it tight enough by hand.
- Even if there was, why would you want to struggle?
-No.
The Honda spec is 16-18LB-FT on the S2000 specific filter.
As Chuck has shown, the attachment is MASSIVELY cheap. Spend $6 to earn your ticket to get off the struggle bus.
I'm sure there are filters out there that call for 7/8 turn from initial contact because the rubber gasket is the first thing to touch the block. The S2000 filter is NOT one of them - there is also a metal ring.
Because of said construction on the S2000 filter,
the 7/8 turn from gasket contact is not as simple to ascertain as you think. Its also just a reference value.
Just torque it to spec. Only you can prevent an engine fire.
#47
lol, i'm good with my s2000 filter.
my question was about non-s2000 filters that also call for 7/8 turns that is done by hand. trying to confirm that these non-s2000 filters at 7/8 turns is not 16-18 ft/lbs like the s2000. (worried about a ford fusion).
#48
I would follow the manufacturer direction. Some filters are just spin on and get tight. Some have a torque spec.
#49
Been doing the s2000 filter by hand for 15 years/250k miles, never had an issue. I am pretty strong, yes. I also don't have the stupid hand slicer/Batt shield in place. Also have not been religious about using an OEM filter, but have strayed when convenient to good quality Mobil one, KN or wix filters.
#50
I've been tightening shift knobs with my eye socket for 17 centuries, since the invention of the eye socket.
I'm like a fukken OX, bruv...but only at the eye socket.
I don't understand the moral of your story. BUT it could be due to the MASSIVE brain damage I've sustained from mysterious events.
