magnaflow catalytic converter
well i was searching for some high flow cats...and so far i saw a magnaflow high flow cat. this would be a great set up since i'm going to buy magnaflow exhaust in the future...... i searched the forums and couldn't find anything on magnaflow cats...... magnaflow shows 2 cats for the s2000 one direct bolt on and the other universal....now i'm thinking would the universal one be a direct bolt on too since it lists honda s2000 under which cars it would fit?
https://www.s2ki.com/forums/index.ph...ic=716627&st=0
Buy a Berk HFC they are cheap and use a magnaflow cat stuff inside.
Best if you buy an exhaust and then a high flow cat because there is two sizes.
63mm and 70mm. So depending on the exhaust you buy a suitably sized HFC.
joefish1298
11-15-2010 06:18 PM
