Main Relay removal help!
I've been trying to replace the main relay to narrow down some issues im having with the car. So i located the main relay but the problem is i dont see how it comes off... I dont see any tabs to push or anything and i dont wanna just yank it out. So if anyone who has replace it before and could tell me how to remove it that would be great!
Originally Posted by AaronSaya
(Post 24572899)
Originally Posted by snitm
(Post 24572921)
Assuming you're referring to the PGM-FI as the main relay. There is a metal bracket that clips into the relay, and then a screw is used to hold the bracket and relay in place. Just remove the screw and disconnect the connector (order doesn't matter)
Pry the insides out of the relay.
What issues were you having with the car and did a new (or repaired relay) solve them?
