Maintenance Advice
Hello,
I recently bought a 2005 Honda S2000 a couple months ago (My first car). I was wondering if anyone had any advice to properly maintain the car. (when to change the oil?, what type of oil to use?, replace the timing belt/chain?, checking the suspension/alignment?, checking the brakes?, interior maintenance advice?) When I bought the car, it had roughly 98,000 miles. It currently has 105,000 and is running fine with no major problems. I am not too car savvy, but this is my first car and I would really like to take care of it. Thanks!!! |
DONT use royal purple transmission fluid , use honda Manuel transmission fluid or gm syncro with friction mod
DO use royal purple 10w-30 in the engine brakes will let you know when they need to be changed...... leave timing chain alone forever unless it starts making noise get takeda intake/big bore thottle body/ ported intake manifold buy a life time alignment from firestone interior = leather wipes and a vacuum cleaner + windex buy rpf1's from tirerack get new spark plugs ngk platinum buy all your oem honda parts from majestic honda and all your after market stuff from evasive and nemos your valves are probably perfect your intake manifold gasket is probably toast |
There is a thread called info for new owners (or something to that effect). Its chock full of everything you could possibly want or need to know. It's concentrated on exactly what you are asking.
Originally Posted by beefystud
(Post 24574422)
buy a life time alignment from firestone also i would advise replacing your coolant, trans, rear diff fluid and brake fluid as preventative maint |
Mileage and spring rates on the ohlins/springs? Thanks
Originally Posted by outeiroj
(Post 24574472)
can confirm this is one of the best value investments you can make. purchased my s2000 in 2013 and have gotten it aligned twice a year since, easily paid for itself
Don't think outeiroj will response. Posted too long ago. If you need alignment every 6 months, prolly driving on potholed roads and/or using the "feel" technique to park, by the curb. :LOL:
do you have pictures of the exhaust and test pipe?
