New PCV valve---hose important?
Old 07-10-2016, 04:17 PM
Greg Bell's Avatar
Default New PCV valve---hose important?
Hey,
I have a an ap1. I swapped out the PCV valve but the old hose was super stiff so I damaged it taking it off. Any reason not to use a standard crankcase vent hose from the auto parts store?
Old 07-10-2016, 05:37 PM
Slowcrash_101's Avatar
Duration of said hose?
Old 07-10-2016, 05:42 PM
Greg Bell's Avatar
If you are asking how long it was on I have no idea? Could have been on for 47k miles.
Is that what you are asking?
Old 07-10-2016, 05:46 PM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
You can use an aftermarket hose with the appropriate internal diameter, you will just need to use aftermarket hose clamps as the Honda ones won't fit aftermarket hoses which tend to be thicker than the oem hose.
Old 07-10-2016, 06:46 PM
Greg Bell's Avatar
Cool--I actually just bought some crank vent hose at O'Reilly's and some screw down clamps. I also ordered a factory one just for why not. They are all cheap. I just wanted to drive my car around this evening because next week is going to be a bunch of endless work!
Old 07-13-2016, 07:06 PM
vtec9's Avatar
Replaced my PCV several times, and I've used auto parts store tubing for that part. But you really need to be careful. Airhose is not good enough. It inevitably gets squishy after awhile from the heat and the suction will compress it and squeeze it tight. I've had issues with cheap "coolant" hose as well. Quality coolant hose should last, but personally, I just pony up a few $ for OEM hose.
czirrfb3
06-24-2022 06:01 AM
treimche
06-11-2019 10:17 PM
samson123
07-25-2015 03:43 PM
djpeak10
09-12-2006 09:18 AM
z_man93
Member S2000 Classifieds and For Sale
10-02-2004 02:33 PM
Quick Reply: New PCV valve---hose important?
