Metal lumps in oil pan - non magnetic
Old 09-05-2015, 11:07 PM
Hasan Shaikh's Avatar
Default Metal lumps in oil pan - non magnetic
Hello Everyone!
A couple of days back I dropped my oil pan to put in a baffle and found some metal lumps in there. They are not magnetic. Below are the pics.
The engine runs fine. There are no abnormal noises etc.
Any ideas what I'm up against and how to go about investigating it.
Appreciate all help and advice.
Thanks
Hasan
Old 09-06-2015, 12:22 AM
I am pretty sure they got clustered when I poured out the oil. Also, might have clusted a few bits myself.
Old 09-06-2015, 12:37 AM
Yes. Removed the plate and didn't see anything out of order. But then, I am no expert on these things and might have missed something very obvious. Should have taken some pictures.
Old 09-06-2015, 04:53 AM
bgoetz's Avatar
Looks maybe like something from tapping a bolt or something. Is the oil drain plug original size? Has there ever been any head work? Do you have aftermarket engine mounts?
Old 09-06-2015, 05:02 AM
The oil drain plug is OEM.
No head work done on the car.
I have megan racing engine mounts.
Old 09-06-2015, 05:08 AM
zeroptzero's Avatar
Received 3,361 Likes on 2,444 Posts
It would be good to know answers to bgoetz's questions above ^
When I first read non-magnetic I thought of bearing material, but it looks too "chunky" for bearing material, when bearings let go they tend to have a more thin and flat cleavage look to them. Based on that I would say they are chunks of aluminum, maybe from around the piston wrist pin, very hard to say though.
Remove the vtec solenoid and see if there is metal on the screen.
Old 09-06-2015, 05:10 AM
Thanks
I have replied to bgoetz's questions.
Will have a look at the vtec.
Old 09-06-2015, 05:24 AM
Slowcrash_101's Avatar
I hope your engine mount bolts aren't digging into the block casing.
Old 09-06-2015, 05:27 AM
Is there an easy way to check this?
Old 09-06-2015, 07:31 AM
zeroptzero's Avatar
There were some instances of Megan engine mount bolts causing block damage, mainly due to improper installation, that would be worth checking.
Quick Reply: Metal lumps in oil pan - non magnetic
