More Clutch Issues
Hey All,
I posted almost a week ago with a problem with my clutch. I wasn't able to get the car into gear (you can read about it here: https://www.s2ki.com/forums/index.ph...&f=22&t=446447). I bled the clutch line on Sunday following xviper's DIY. Everything went fine with the bleed. The clutch still didn't feel quite right, but I was able to get the car in gear and drive it. Well today I was on my way to an appointment and hit 2nd gear. I was at about 4500rpms when the car lurched as though I had hit the rev limiter or it wasn't getting gas. This happened in both 2nd & 3rd gear. Then I also noticed a lag in 2nd before I hit that lovely lurching where it seemed like the tranny was trying to catch up to the engine. Is this a sign that the clutch is indeed going? Anyone have a similar experience. Here are the details on the car: -03 with 40k on the clock -Stock clutch -Clutch line flush/bleed (used syn brake fluid DOT3, 4 & above) -No track time I appreciate any help. Thanks! -jeremy |
