More TCT Analysis / Questions
Bought a Ballade TCT, ran it for about an hour and heard a whine. Never used bolts to force it in, fit it by hand and torqued to spec after it was flush. Realized it’s best suited for people with more agrresive cams, removed it. Decided to go back to stock until I order my Billman, but sandblasted my worm gear in hopes of a temporary fix. ALSO did not force that in, I tensioned with an M5 long screw and sat it flush, but now IT is making a very very faint, but subtly audible when the engine is warm, whining sound. Am I in trouble, should I not drive it? I wouldn’t think that the stock TCT would overtension the chain, maybe there is always a soft whine and I didn’t notice before as I had only driven this car 200 miles after purchasing before starting this maintence. Any opinions help, thank you. |
The damage to the chain and camwheel bushing are likely already done. Bolt retracted tensioners come in an incompletely compressed form. If there is zero clearance between the tct piston and the guide upon installation, it will serverly overtighten the chain, as there is no room for expansion as the engine temperature rises. |
Originally Posted by Billman250
(Post 24578746)
The damage to the chain and camwheel bushing are likely already done. Bolt retracted tensioners come in a completely compressed form. If there is zero clearance between the tct piston and the guide upon installation, it will serverly overtighten the chain, as there is no room for expansion as the engine temperature rises. |
Originally Posted by mr.penis
(Post 24578752)
Hm, so at this point in time at I risking more damage by driving? What is the solution/your recommendation for my next course of action? |
Originally Posted by Kyle
(Post 24578760)
Replace some parts and run his TCT.
EDIT: Billman Gen-X ordered. |
You realize that you prolly need to change the timing chain. This seems like a pretty major to-do. Much more than changing the tensioner, only.
https://www.s2ki.com/forums/s2000-un...ement-1167700/ |
(Post 24578772)
Couldn’t find anything called a camwheel bushing. What parts should I be looking to replace? Sorry for all the questions, just haven’t had owned an S before. EDIT: Billman Gen-X ordered. |
Originally Posted by windhund116
(Post 24578780)
I'm very lucky and got to the S2Ki site, before I even heard of Ballade Sports chain tensioners. So, I know nothing about the Ballade's product. But, as for Billman's tensioner... I don't think I've ever heard of a complaint from anyone who used it --- provided it was installed correctly.
:) https://www.s2ki.com/forums/s2000-un...oduct-1097843/ |
I have had a ballade tct on my car for about 5 yrs now and probably 30k miles.No issues that I know of**knock on wood. Been meaning to grab a billman unit for some time now.
any issues doing that now billman??? |
