multi meter and spark plug?
Old Jan 4, 2008 | 11:16 AM
mikitymike55's Avatar
Default multi meter and spark plug?
How how do i test my spark plug and coil pack with a mulimeter? What should the readings be on the spark plug and coil pack?
Old Jan 4, 2008 | 07:41 PM
jeggy's Avatar
to test spark plug/coil plug combo:
1)remove coil plug from valve cover
2)remove spark plug from cylinder head
3)insert spark plug back into removed coil
4)plug in coil connector
5)grasp spark plug near electrode and hold it near chassis ground
6)have assistant crank engine
results:
if you yell "HOLLY MOTHER F**&^G GOOD GOD THAT HURTS!!!!"
then the spark plug is good.
if you dont yell anything then you have problem where the spark plug is not getting spark.
ok, by now you should realize i'm just talking BS.
heres the real answer:
theres really no way to test a spark plug.
the coil plug i belive you check the resistance of it through the connector.
the actual numbers of a good coil and bad coil i do not know.
this is where a repair manule will help you step-by-step.
Old Jan 4, 2008 | 07:48 PM
RedY2KS2k's Avatar
jeggy, I like your description of the experience. It brings back (unpleasant) memories of days gone by...
Old Jan 4, 2008 | 08:47 PM
jeggy's Avatar
and for some dumb reason, the guy standing next to you when it happens always dares you to do it agian...
Old Jan 4, 2008 | 09:27 PM
RedY2KS2k's Avatar
Yeah, kind of like the guy who tastes the milk, makes a face, declares that it's sour, then asks you to taste it.
FireDog
Sep 13, 2013 02:08 PM
essi1553
Aug 22, 2010 04:15 AM
macr88
Engine
Jan 21, 2010 10:48 AM
