Mystery flashing cel..
Hey guys, I ghost cel and honestly I cant figure it out.
Year: MY02 Miles: 112k Oil consumption: Roughly 1.5 quarts per 1,000 miles. (Which is normal for my driving style, been that way since I got the car with 60k miles) I know a flashing cel means DONT DRIVE IT but I cant ever seem for the cel to stay on and it drives perfectly normal. It ONLY flashes when I'm in 6th gear staying on the gas flooring it from around 65mph to around 80mph then vanishes once I let off. I think thats around 3500 rpm to around 4500-5k rpm if I'm not mistaken? During city driving I never see the cel, which is really weird as I mainly drive city and dont see the flashing cel for 2-3k miles at a time. No power loss and no misfires. It really only happens when I'm in 6th and flooring it to pick up some speed to merge onto the highway. If I'm on the highway in 6th driving regularly not pushing it I never see the flashing cel. Any ideas or would the best option is to get a obd2 sensor and recreate the situation where it flashes (aka: go on the highway on 6th and floor it with a obd2 plugged in hoping it will pick up the code so I can figure what the hell it is?) https://www.amazon.com/Autel-MaxiSca.../dp/B001LHVOVK Was looking at a cheapo obd2 sensor to just get the job done Edit: obd2 scanner wont work Here's a clip of just city driving, that rattle is the seat hitting the factory roll bar by the way and the glass clings is a bobble head lol. Dont mind the big pot hole in the beginning :( Well I took the highway home today and got the cel to flash and then stay. I then remembered that one time it flashed and it did stay solid when I was going out to go eat one day. But when I was going home from eating it was gone and I forgot about it for a while. I took the video because I thought it would happen again and yup, turned off :banghead: |
Yeah, I'd try to get that CEL error number. Maybe, it's still stored in the ECU memory?
Originally Posted by windhund116
(Post 24091304)
This is very interesting...
Here's a clip of just city driving, that rattle is the seat hitting the factory roll bar by the way and the glass clings is a bobble head lol. Dont mind the big pot hole in the beginning :( https://www.youtube.com/watch?v=cJCRSxKjKJs Well I took the highway home today and got the cel to flash and then stay. https://www.youtube.com/watch?v=j1-vpDXC76E I then remembered that one time it flashed and it did stay solid when I was going out to go eat one day. But when I was going home from eating it was gone and I forgot about it for a while. I took the video because I thought it would happen again and yup, turned off :banghead: https://www.youtube.com/watch?v=zQjZzlPsIY0 I'm at a loss, I guess I could try and get it to come on again and drive straight to a autozone and have them pull the code. Anyone have any other ideas? All stock except a greddy ti-c exhaust with matching test pipe. Do you think its possibly the tp thats giving the cel? But then again I never heard of a tp causing a flashing cel :scratch: |
Is it possible that it could be stored as a pending CEL?
Originally Posted by s2cho
(Post 24091292)
.. It ONLY flashes when I'm in 6th gear staying on the gas flooring it from around 65mph to around 80mph then vanishes once I let off...
Maybe you were lugging the engine too much, try downshifting to 5th. |
Originally Posted by Soviet
(Post 24091342)
Originally Posted by kukudm
(Post 24091353)
Well I've been pretty busy and couldnt go to a autozone, I'm planning on doing some maintenance this week/week end hoping it'll fix it.
Ill be doing -Air filter change (pretty dirty, last changed around 20k miles ago?) -remove catch can hoses back to factory locations to see if thats the problem (breather filter could be clogged up) -get a new pvc valve If those dont fix it -Get injectors cleaned with the cool machine -possibly get new spark plugs (from my knowledge the ngk BKR8EIX (iIridium plugs) last like 60k-100k if I'm not wrong, last changed around 30k miles ago) -kick the car |
Add buying a code reader and posting your stored code(s) to the top of the list...
Originally Posted by HarryD
(Post 24092752)
But an obd2 scanner wont do any good after talking to some people who are familiar with obd2 sensors. The steps for nearly every obd2 sensor is 1). ignition has to be off 2). plug in 3). turn ignition on 4). scan But looking at that third video I posted, the cel vanishes once ignition is off and turned back on. My friend told me the the higher end obd2 scanners like the Autel's can possibly do real time scans but the cheaper ones can only read stored codes. So getting a code is very unrealistic near impossible unless I'm trying to spend 3 grand on a obd2 system which I'm not going to do lol |
