Need help with Rattle noise coming from either clutch housing or Transmission
He bro have your driveshaft checked . Mine made the exact same noise took the driveshaft off and had a driveshaft place test it out and it made the noise bro . Currently a shop is making one for me for 495 better than 700 plus from Dss but this is there first time making one so we will see how it goes ill keep you guys posted
I have a 2000 AP1 and I had a transmission rattle too. It occurred in all gears, even neutral, when clutch was pushed in, everything. It would happen when driving straight, and turning right, but it would go right away when I turned to the left. I thought I needed a new clutch, then a tranny, but the actual problem was super weird. So you know how the oil cap on the top of the engine is right at the back of the engine bay? If you're a little too aggressive with spinning that off, it can actually fall behind the motor, and get stuck on top of the transmission. Sounds unlikely, and I dismissed this for a month but I have a friend who has an inspection camera so I thought I might as well. Turns out that little bastard was right on top of the transmission, where the tranny meets the engine. If you can, do a check. Does it have an aftermarket or oddly new oil cap? Something to check, especially if it saves you from getting a new tranny or clutch.
