need some vafc wiring help.......
i got everything wired up except for the tps..... can anyone tell me which pin it is?? i figgered it was like a normal honda and was a red/black... so i wired it to the only red/black i saw and thats not the right one.........
I don't know the answer to your question, but would possibly like some help from you when I get my VAFC in about 2 weeks. how did you mount it and where?
im actually installing it for a customer........ he is going to have it recesed into the sun visor....
i used a fields afc harness adapter. the only difference is that the fields unit does not use throttle possion at all.... |
The throttle position pin is on the blue connector to the ECU. It is in the row that has 9 pins (3+3+3), and it is the pin in the center of that row(5th count from either side).
what color is the TP wire??
Originally posted by wadzii what color is the TP wire?? |
