No A/C, no Heat ...no bueno!
[left]Hey guys so I’ve searched this and it seems people in the past never updated their posts to state the actual problem. Essentially I’m getting no air from the vents, and this happened AFTER I changed my battery. For a little background, my car is running a hondata ecu, and I have checked the basic fuses. I did not check the resistors. The lights on the dash work, but the clutch fan for a/c does not seem to go on, I tried hitting the fan under the passenger side dash (don’t hear it on though), and before I buy a thousand parts just looking to see if I can get any solid clues. Thanks
Which lights on the dash work? The series of green lights that track how high you've set the circulation blower fan?
So the switch says the fan is on, but fan doesn't actually blow?
And also if you turn on AC, the green ligjt on the AC bitton lights, but the compressor never turns because its clutch doesn't engage?
Is all that correct?
Oh, and this doesn't belong in modifications. Should go in Under the hood.
The green lights on the right pod that houses the hvac controls. Green light for A/C also works. You are correct, clutch doesn’t engage and the heat also does not blow air. No air at all blows.
All fuses are okay?
All fuses are ok. I think it may be the large relays just wanted to know if there is a way to test them etc? Maybe something really obvious. Air goes through the vents when I drive but doesn’t work as normal.
