no compression across all 4 cylinders
just did a leak down and all 4 cylinders are 80% leaking...
after the leak down no air is coming out of crank case or the head??? what could it be??? been in the shop for the past week... |
Could be that the test is not being done right. Which one did you do, a real leakdown test? Wet?
Originally Posted by mLeach,Nov 18 2009, 02:28 PM
sounds like the car is not timed correctly, or all valves are bent.
does the car run??
you should be able to hear the air easily with that much leakage. listen at the tail pipe, if you hear air rushing out then its the exhaust valves. Listen at the throttle body, if you hear air its the intake valves Listen at the oil cap, if you hear air there its the rings or the headgasket. |
Originally Posted by wadzii,Nov 18 2009, 02:40 PM
does the car run??
you should be able to hear the air easily with that much leakage. listen at the tail pipe, if you hear air rushing out then its the exhaust valves. Listen at the throttle body, if you hear air its the intake valves Listen at the oil cap, if you hear air there its the rings or the headgasket. I havent tried to listen out of the tail pipe... nothing out of the oil cap...I think there was slight air coming out of the throttle body.. |
with 80% leakdown the engine isnt going to want to run... id bet either the cam timing is off or the tester is messed up/done wrong. what are the compression numbers.
are you using the stock ecu? |
are you using the stock ecu? I believe the compression on #1 is 90, and the rest is at 50... running a aem stand alone..have a 2mm cometic head gasket so I think the compression should be around the 120 mark? |
my aem was doing that.. it didnt want to restart on a warm start up if it died. i replaced 2 resistors and all was good.
but you should have ~150-180psi i think.. its been a while since i have done a compression test on a s2k w/a thick hg. but with 90 and 50.. its time for a rebuild, no since in speculating. its got to come apart to fix |
