No start after engine swap
#21
#24
What is the bad code with the AP2 ECU telling you ?
#26
this may help if you have dislodged a yellow/black too your ecu/relay ect
https://www.s2ki.com/forums/s2000-un...ation-1110963/
#28
P1607 EGM/PGM Internal Circuit Failure A
may be check the plugs & wiring then,if not done already to make sure a spade has not been pushed out.
Other than that I am stumped !!
#29
swapped crank position sensors and both cam sensors from my other motor
still not firing
pulled valve cover for the 8th time and verified TDC with a socket extension and the two cam marks and the white crank pulley marks are all where they should be.
still not firing
#30
-Key off
-Turn key on, note status of CEL over a 45 second period, noting what happens around 25-30 seconds
Post the sequence...
Ex: CEL on for two seconds, then off, then flashes xxx at 25 second mark, etc.
What year is the car, does the engine have the proper crankshaft trigger wheel for the current ECU?
