No start after engine swap
#41
I agree here 100% I believe there is some sort of timing problem. I've verified TDC with a socket extension with the white mark on the crank pulley, lined up the chain gear with the cylinder head, and lined up the cam gears by their marks. I don't know how else to verify timing.
The map sensor was never plugged in running the ITBs. The CTS is reading 78F which seems about right given ambient temps. I am using a aftermarket TPS that reads 0.5v at idle which I've clocked to about 6% TPS in the ODB2. I bought the wrong air temp sensor and its currently reading 137F but I've swapped in the OEM air temp sensor and that didn't make any difference when it was reading 80F.
#45
Glad your up and running
#46
Wow, that was a difficult diagnosis. Good job.
#49
I just clicked into this forum because My Mechnic dealing with the same problem. So I thank you for figuring it out, I thank you all for giving so many options of what it could be. I thank you all hopefully we can figure this problem out.
seymourless
02-02-2017 03:14 AM
Jouchan
09-22-2011 03:17 AM
