Noise identification help - transmission
Old Oct 3, 2013 | 04:20 AM
starchland's Avatar
Default Noise identification help - transmission
Around 21s you can really hear it, happens when I let off, when cruising the noise goes away mostly. Bad case of clutch buzz?? Thanks for viewing.
http://youtu.be/XTFuzpQqG8Q
New video at idle , 6 th gear:
http://youtu.be/RFzQhaVlf_s
Old Oct 3, 2013 | 06:40 AM
franky's Avatar
not sure but sounds like clutch buzz. Mine has it too but it doesn't bother me.
Old Oct 3, 2013 | 02:13 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Clutch buzz, 100%.
New OEM disc from Honda will cure it.
Old Oct 3, 2013 | 03:09 PM
starchland's Avatar
Thanks guys for confirmation.
I will leave it, won't bother changing it until it is detrimental to the car
Old Oct 10, 2013 | 04:47 AM
starchland's Avatar
Here is another video from under the car. Is that clacking noise normal or do I have a problem? Thx
New video
Old Oct 10, 2013 | 01:18 PM
Billman250's Avatar
Top Answer: 1
Sometimes when a driveline is spun with no load, you can get noises like that.
just make sure it doesn't do it on the ground while driving.
JRC
Jan 3, 2017 11:20 PM
S2kristopher
Dec 11, 2013 06:23 PM
ivory90
Oct 10, 2012 06:22 AM
dwart
Jan 9, 2007 12:42 AM
AROD
Dec 8, 2006 07:05 AM
