Notchy Steering
Old 02-20-2016, 04:35 PM
Avionics86's Avatar
Default Notchy Steering
Car is a 2002 with 38K recently developed a notchy feel when turning left or right then goes away in a few minutes. Car has been in Florida it's whole life and is garaged kept. Never raced or any accidents. Problem stated awhile ago and has not gone away. Could this be caused by not being driven or maybe a bad EPS? Been doing a lot of reading and the people with is problem replaced the Torque Sensor and that fixed the issue. Car drives great after a few minutes so I do not believe it's mechanical. Anyone else have this issue?
Thanks
Old 02-20-2016, 05:08 PM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
Turn the steering lock to lock with the engine off, key in ignition. See if the notchy sensation still occurs without power. That might tell you if it is a bad suspension part, or an electronic issue with the EPS/Torque sensor. Do it in a garage so you can hear any binding that might be occurring with suspension parts, you can do it with the wheels on the ground and also with the front wheels jacked up in the air.
Old 02-23-2016, 02:36 PM
ahrmike's Avatar
Does it fix itself once warmed up? Usually worse at night/when its cold? I think its the grease in the sensor. I made a simple write up of it a while back...
Old 02-23-2016, 05:38 PM
Avionics86's Avatar
Thanks for the reply and I might try this or just replace the Torque Sensor but I need to remove it first. I have the factory repair manual and basically it states line everything up and remove the two bolts and remove the sensor. There are allot of posts stating you must get a special tool and remove the rack alignment assembly. Since you have removed your torque sensor do you have to mess with the rack alignment?
Thanks
Old 02-25-2016, 04:47 PM
ahrmike's Avatar
Replied to you on PM but replying again for whoever digs this up:
I didn't loosen the large bolt, I read about it in the DIY too. It might help release some tension on the helical sensor gears but I was able to rotate the sensor out with no problem.
fri3dric3boi
01-17-2017 07:22 PM
91crxSi
03-10-2015 06:24 PM
bsheep83
03-13-2013 06:53 PM
silver696
01-16-2012 01:48 PM
stvtrnr
09-23-2007 08:19 PM
Quick Reply: Notchy Steering
