Oil filter question/loose oil filters
Old 02-04-2019, 08:00 PM
czirrfb3's Avatar
Default Oil filter question/loose oil filters
I was reading when installing a new filter you can do "7/8 a turn." I couldn't find the correct size oil filter socket so I bought a strap wrench.
My confusion comes from do I basically hand tighten it until I get some resistance then use the strap wrench and do almost a full another turn with resistance?
I didn't think installing a filter was complex but I read in other forums with the S2K it needs to be a very exact method or my car will catch fire.
czirrfb3 is offline
Old 02-04-2019, 08:11 PM
Deckoz's Avatar
The filter is marked with 1 through 8 text along the circumference.
Screw the filter on until you feel it start to touch the mating surface, you want it to feel like the whole ring has started to touch, not just one side of the filter.
STOP.
Whatever angle you are looking at the filter at, note the number, lets say its three.
Tighten the filter until the 2 is in the position the 3 was, or 7/8th turn after contact.
But yea you got the idea in your first post. Just check the number markings on the filter so you can clock your turns easily
Deckoz is offline
Old 02-04-2019, 08:17 PM
czirrfb3's Avatar
I guess the "7/8th a turn" is confusing me I am trying to visualize how much of a turn that is. To me a "turn" would be a full 360 so 7/8 would be like 90% of that?
Or would a "turn" be more of a 180 than 360?
czirrfb3 is offline
Old 02-04-2019, 08:29 PM
Deckoz's Avatar
(360 / 8) * 7 = 315°
Like I mentioned, there are numbers around the oil filter. marked 1 through 8.
each number represents 1/8th turn. if you tighten from above, and the gasket touches flat, look at the number ring and see which one is closest to you, this time lets say its 5. Now tighten it, until you can see 6 where 5 used to be .. then 7...8...1..2..3..4. Or 7/8ths of a turn. if you turned it back to 5 that would be a whole turn, or 8/8ths.
Deckoz is offline
The following 2 users liked this post by Deckoz:
hirev (02-11-2019), LaosguyAP1 (02-05-2019)
Old 02-04-2019, 08:35 PM
afzan's Avatar
I use a CTA Tools A257 oil filter wrench, can be had for very cheap on ebay:
https://www.ebay.com/itm/CTA-Tools-A...1&isGTR=1#shId
afzan is offline
Old 02-04-2019, 09:25 PM
czirrfb3's Avatar
That gif helps immensely!
czirrfb3 is offline
hirev (02-11-2019)
Old 02-04-2019, 09:30 PM
czirrfb3's Avatar
So. Basically hand tighten the filter until I feel the seal touch. Then whatever number is facing me I turn the filter tightly until I am 1 number behind whichever number was facing me when the seal made contact?
I kinda feel like people are being overly-cautious and I'm sure tightening it by hand until you feel confident its tight enough will be just fine, but I guess it's best to just do it the 100% correct way.
czirrfb3 is offline
Old 02-04-2019, 09:48 PM
flanders's Avatar
This is correct and no, just going hand tight is not enough to be 100% sure it wont get loose.
flanders is offline
Old 02-04-2019, 09:56 PM
czirrfb3's Avatar
So will I need to use my strap wrench once the seal makes contact? Or can I hand tighten the rest of way until I get to the number I need to be at?
czirrfb3 is offline
Old 02-04-2019, 09:59 PM
noodels's Avatar
Needs a strap to engage more psi..
noodels is offline
Quick Reply: Oil filter question/loose oil filters
