Oil filter question/loose oil filters
Old 02-09-2019, 08:42 AM
  #61
cosmomiller's Avatar
Received 1,555 Likes on 924 Posts
Originally Posted by czirrfb3
The strap wrench I got was totally useless it didnt grip at all and just slid around so I had no choice but to hand tighten as hard as I could.
So far car drives totally fine.
Every S2000 that had an engine failure from oil starvation or an engine fire from oil spraying over the engine was driving totally fine right before.
cosmomiller is offline
Old 02-09-2019, 09:35 AM
  #62
Chuck S's Avatar
Received 1,131 Likes on 994 Posts
This has gone on long enough! Step away from the strap wrench. Spend the $6 on the A257 oil filter wrench listed by several earlier posters (in stock at AutoZone or Walmart) and tighten the oil filter 7/8 turn if you don't have a torque wrench which is no more than $20 at Harbor freight and often on sale for $10. That's the same torque wrench you should be using for the engine, gearbox, and differential fill and drain plugs, and the spark plugs (unless you're guessing at these as well).
I'm beginning to think you have some emotional attachment to the strap wrench. Deal with it!
-- Chuck
Chuck S is online now
Old 02-09-2019, 09:52 AM
  #63
czirrfb3's Avatar
Originally Posted by flanders
How far did you reach when torquing the oil filter, 5/8?
The filter with the 5 facing me would have been 7/8 I got to 3 by hand.
czirrfb3 is offline
Old 02-09-2019, 02:42 PM
  #64
Hfreak's Avatar
So you got Flanders predicted 5/8 of the required 7/8 which means you are 1/4 of a turn off, break out your strap wrench.
Hfreak is offline
Old 02-09-2019, 04:30 PM
  #65
zeroptzero's Avatar
Received 3,361 Likes on 2,444 Posts
The last couple oil filter marks are difficult to get to hand tight as the metal edge of the oil filter needs to butt up tight to the mount base. That ensures proper outward force is put on the filter so it will remain tight and no risk having if spin off. I have to say the Honda oil filter wrench is just about as perfect of a design as you can get, well worth the money.
zeroptzero is offline
Old 02-09-2019, 11:31 PM
  #66
czirrfb3's Avatar
Brought the car to my uncle's he used his tool and we got it to between 4 and 5 so that would be like... 6.5/8th a turn? He is a diesel mechanic and told me that filter is on there good.
czirrfb3 is offline
Old 02-10-2019, 02:54 AM
  #67
Slowcrash_101's Avatar
I use the strap wrench all the time to good effect. Never ran into a filter I couldn't undo with one. Even the cartridge filters.
Slowcrash_101 is offline
Old 02-10-2019, 11:00 AM
  #68
Car Analogy's Avatar
Received 1,311 Likes on 991 Posts
Ok, so someone with zero experience with oil filters of this design says its good enough?
Car Analogy is offline
Old 02-10-2019, 11:20 AM
  #69
czirrfb3's Avatar
As I said he is a diesel mechanic for pepsi and he has owned nothing but Hondas over the years and done engine swaps. I trust him. and the extra .5 of a turn I think isn't going to make a massive difference.
czirrfb3 is offline
Old 02-10-2019, 01:48 PM
  #70
Chuck S's Avatar
Anything to save six bucks for an oil filter wrench.
Yep, diesel and S2000 are practically the same thing.
-- Chuck
Quick Reply: Oil filter question/loose oil filters
