Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
Oil filter question/loose oil filters
Old 02-04-2019, 10:00 PM
flanders's Avatar
You can try to hand tighten all the way of course but very few (none?) have the strength to get it to 7/8.
Now you got a challenge
flanders is offline
Old 02-04-2019, 10:02 PM
I was going off this video and at 1:03 he does the filter fully by hand it seems.
czirrfb3 is offline
Old 02-04-2019, 10:10 PM
flanders's Avatar
Or didn't have the time to show when he went to get the tool and did the last torque down.
You got all the information you need now, I bet there are hundreds of videos with people doing it incorrectly, no need to waste your time on that.
flanders is offline
HarryD (02-04-2019)
noodels's Avatar
Originally Posted by noodels View Post
Needs a strap to engage more psi..
noodels is offline
Old 02-04-2019, 10:44 PM
^^ This, dont waste your time on those videos, if you are really in doubt, check the instructions on the side of the filter. Honda specified these numbers so the filter doesn't get shot off like a bottle rocket. Even the 7/8ths and torque are mentioned and can be seen in the gif I made earlier
As well as @flanders mentioned it s almost impossible to torque it by hand. You have to keep it moving, once you get to 3/8ths turn don't stop until you reach 7/8. Keeping momentum is the only way I can do it by hand with a grippy glove on. If I stop before 7/8ths I can't tighten it all the way and have to grab a tool as I cant restart the momentum because friction.
also... you have three names lol
@czirrfb
@czirrfb2
@czirrfb3
Deckoz is offline
Old 02-05-2019, 03:08 AM
The spec is 15 to 18LB-FT OR 7/8 turn.
Hell no, you cannot get there by hand.
If you can, you probably did it wrong OR you should dial 911 about your hands.
Strap wrench works fine. Use 7/8 turn as a guide. Hopefully, you are able to "feel" out 18LB-FT using your handle length.
Or buy the Honda tool for $30 and use a torque wrench.
This only works for the factory Honda filter as it is not a traditional type of filter.
B serious is offline
Old 02-05-2019, 05:40 AM
Chuck S's Avatar
Use your torque wrench with the oil filter wrench. So much easier than all that complicated math and trying to figure out when to start counting the rotation or when the gasket touches or .... 16 lbf-ft
The CTA Tools A257 oil filter wrench has a 3/8" socket on it and is like 6 bucks at AutoZone, you don't need a $30 Honda-branded tool. Buy the wrench the same place you got the oil.
You must use the specific oil filter for this car. Note Jason's car had some sort of Brand X filter he removed.
-- Chuck
Chuck S is offline
Old 02-05-2019, 07:00 AM
I ordered
"Genuine Honda 15400-PCX-004 Oil Filter"
From amazon.
czirrfb3 is offline
Old 02-05-2019, 07:03 AM
I'm kinda surprised there is no video on YouTube showing someone doing the filter install the proper way seems like something that easily can be screwed up. I imagine there are tons of S2K's out there that went to oil change places and the techs didnt do the "7/8 turn" method.
czirrfb3 is offline
Old 02-05-2019, 07:18 AM
windhund116's Avatar
windhund116 is offline
Quick Reply: Oil filter question/loose oil filters
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
