Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
Oil filter question/loose oil filters
Old 02-05-2019, 07:19 AM
  #21
I've ordered a few things on Amazon so far. I also have replaced the antenna with a "stubby" one, got one of those broadview rearview mirrors and a new timing chain tensioner (but ordered a low quality one so I'm sending it back)
But so far these are what I've purchased.
- Floor mats
- Shift knob
- Aluminum battery tie down bracket & hardware
- 15400-PCX-004 oil filter with crush washers
- NGK (7772) PFR7G-11S Laser Platinum plugs
Nothing crazy so far once I get the car solid I'll start working on visual things like a quick release wheel, coilovers wheels etc. But next I'd like to get the proper TCT and do a valve adjustment and check the retainers for cracks. I'd also love to paint the valve cover.
The car has a fairly new lightweight clutch and flywheel and a K&N short ram intake (the cone could use replacing).
czirrfb3 is offline
Old 02-05-2019, 07:20 AM
  #22
Originally Posted by windhund116 View Post
The OEM filter is 3-inch (76mm), 15 flutes. I just one of these and use a torque wrench.
https://www.amazon.com/CTA-Tools-A26...+filter+wrench
I couldn't find the proper oil filter socket so all I have is the strap wrench. I don't feel like ordering that because I just paid $7 for this strap wrench lol.
czirrfb3 is offline
Old 02-05-2019, 07:22 AM
  #23
windhund116's Avatar
I got this from Amazon. Maybe, return the strap? Fixed filter wrench is mucho easier --- in the area you need to work. IMHO.
Well, with my torque wrench being a little on long side and the oil filter tilted slightly downwards --- the fixed tool works better (for me). Maybe, try the strap and see if you have any issues. Another thing --- watch that sending unit which is sticking out of the engine and begging to be stuck and damaged.
windhund116 is offline
Old 02-05-2019, 07:25 AM
  #24
Didnt someone earlier in the thread just say a strap wrench will be fine? So now I'm confused >_<
I have skinny arms if that helps. Also I dont have the stock air box the filter is staring me right in the face when I open the hood.
czirrfb3 is offline
Old 02-05-2019, 07:30 AM
  #25
Should be, I have always gone hand tight and it has worked for 10+ years; however following proper procedure eliminates the guessing game and gives you peace of mind, while eliminating the possibility of destroying your motor or car.
starchland is offline
Old 02-05-2019, 07:55 AM
  #26
Wait. You said you go hand tight? People just said in this thread its impossible to hand tighten the filter on these cars?
I'm getting mixed up here. People say "use a torque wrench." Then "you'll be fine with a strap wrench." Then "it's impossible to hand tighten" then "I hand tighten".
czirrfb3 is offline
Old 02-05-2019, 07:56 AM
  #27
LaosguyAP1's Avatar
this is the oil filter tool i use.
Amazon Amazon
LaosguyAP1 is offline
Old 02-05-2019, 08:11 AM
  #28
if you are in the unsureity camp, do it the right way with a torque wrench. the filter markings can be open to interpretation apparently.
Hand tight means I get it as tight as I can with my hand.
Old 02-05-2019, 08:12 AM
  #29
Just goes to show you, sometimes you can find misleading (and sometimes even wrong) information on the Net. But, you knew that.
Old 02-05-2019, 08:13 AM
  #30
Excuse my terrible hand writing but you guys are helping, I'm taking notes of everything but I wanna be sure I do it the correct way.
czirrfb3 is offline
Quick Reply: Oil filter question/loose oil filters
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
