Oil filter question/loose oil filters
#31
#32
If you are looking for unanimity on any issue regarding the S2k you have come to the wrong place.
#33
Lol...you posted a thread on the internet starting with "oil". It gets everyone WAY too excited.
Let me break down the methodologies into a simple format:
A strap wrench and the 7/8 turn method works fine if you know what you're doing.
Its 7/8 turn after gasket contact. The tricky part is knowing when the gssket has actually contacted.
For this reason...7/8 turn is a REFERENCE measurement that's used as a secondary way to make sure you got to the right torque setting. 18LB-FT is an exact measurement. Knowwhatimean?
So while it doesn't ultimately matter how you get the filter tight enough....the SAFEST bet is to use a tool that allows you to torque the filter.
Also...
Anyone doing this by hand with an OEM filter is out of their effing minds. Its like tightening your drain plug with a pair of pliers and following up with, "that'll hold 'er".
Also...
#34
#35
Also...
Also...
#36
Also...
Also...
#37
I can get it about 3/4 of the way by hand. I am no hulk, but I am not weak either. But again, why would I want to strain to do it when there is a simple, way more effective way?
It is simple to feel when the gasket contacts. Then use the numbers on the filter to do the rest. you do not need to be to the 1lb*ft accuracy. Otherwise they would not put the numbers to use on there instead since that is not totally accurate. But you will notice that last 1/8 turn and it does make a difference.
people just like to argue about EVERYTHING on the internet. Most are just making it too complicated.
I remember when I was 18 and was helping out at my dads shop. I was putting a serpentine belt on and I had a wrench that fit next to me. Dad saw me about to use it and mentioned he had the longer tool made just for that in the box. Of course I was 18 and "could do it with this short wrench easy!!". So I did. Since I was putting so much force on that short wrench, when it slipped due to an odd angle it was in, I put all my weight into my hand against a piece of metal, split my fingernail all the way down and bled like a stuck pig. He just chuckled and handed me the proper tool. Just cause you can does not make it the best way
windhund116 (02-05-2019)
#38
Advice from the School of Hard Knocks, is often the best.
#40
Not anywhere near 18.
18LB-FT would require you to put a 133LB force the tangent edge of the filter while gripping the filter hard enough to hold that. Inside an engine bay. Nobody that's not in some sort of world record book can do that.
You're probably outputting like 5-8LB by hand while riding the struggle bus to a terrible destination.
Why in the world would you want to do this by hand? Its more difficult AND you're risking failure.
