Oil leak from allen screw in front of engine.
#31
It is very easy.
It is also imperative that the camwheel bolt is properly tightened so it doesn't come loose.
Think I will do a torque test on my test head to come up with a solid number.
#32
I thought spec was 30 ft/lbs?
As preventative measure I wanted to retorque mine to make sure it wasn't coming loose, so did a search and iirc numbers I found were 30 ft/lbs.
Turns out mine wasn't loose, but I felt better knowing it was good.
Saki GT (05-17-2020)
#35
You'd probably break the bolt around 75ft lbs.
s2k.tay (01-07-2023)
Saki GT (05-27-2020)
#38
I replaced that o-ring on my previous s2k and torqued to 36 ft/lbs. I sold the car and after a couple years I heard from the same guy that cam wheel had dropped down and destroyed the motor. I also heard he boosted it. I always wondered if it was due to that cam wheel bolt or maybe something else he did. I was thinking how much more TQ can that bolt take.
