Oil leak... from the oil pan or somewhere else?
I check oil every 1000 miles. I'm always peeking under the hood to make sure things are good. It's how my Focus got to 180k miles and so far only 1 sensor needed to be replaced in the cooling system. Still running strong. I'm being more careful with the S2K, since it's a performance car.
Seeing as I got the car in June and I've put over 17k miles on it, I'm checking pretty frequently :P
After I initially got the car, it started sounding funny after a month or two. I checked the oil and discovered it was DRY. (I had planned on doing some early maintenance work but was basically just super busy). After that, I really got on top of it.
It looks worse than it really is. I lost a quart over about 1000 miles. It's not too bad. I tightened the filter a bit this morning, I'll grab my oil filter wrench and give it some torque later tonight. I'll keep an eye on things after I wash it to make sure there is nothing else going on. Hard to plan major maintenance when I'm working full-time and school full-time. Great feedback everyone, very helpful. I would not have known about the extra torquing.
Received 1,562 Likes
The OEM oil filter is built differently than standard auto (including Honda) filters. Standard filters have the O ring that can be hand tightened. The S2000 filter has two metal rings with a gasket sandwiched between. You must use a torque wrench or wrench on the filter to ensure the 9/10s rotation is achieved. Why? The OEM filter needs to be cranked down so those 2 metal rings make contact with the mating surface on the engine. The gasket provides the seal but not the locking torque like a standard filter.
cj_in_seattle (12-08-2016)
What's the next logical step for the OP to rule out (or prepare) for a bearing failure due to oil starvation?
Getting his oil tested by Blackstone Labs and looking for high metals/bearing material in the report?
So yes cleaning the engine is a good thing, also it looks like the oil is coming from above the pan...almost like when an oil change was done it is spilled oil not cleaned up? a new filter would get rid of the worry about oil coming from that....i use honda s2000 filters not accord or civic ones...and i hand tighten them and have done so since 2004 when i did my first, i have done all oil changes since them save for two, so whatever i do works. best of luck with this.
