Is the oil plan weldable?
Old 03-17-2018, 08:14 AM
st.ryder64's Avatar
Default Is the oil plan weldable?
The NPT threaded hole that was drilled into my oil pan by a previous owner was run in too far, so the male adapter will never seal. Considering having a friend TIG the adapter in place, but is that pan straight aluminum or pot metal? Anyone tried to weld on one?
Old 03-17-2018, 08:51 AM
Hfreak's Avatar
It is cast aluminum and can be welded with a TIG.
Old 03-17-2018, 09:09 AM
DavidNJ's Avatar
Moroso sells a baffle that is welled in the pan. There are several threads about installing it.
Old 03-17-2018, 09:20 AM
cosmomiller's Avatar
Received 1,556 Likes on 924 Posts
You can clean it down to the metal and JB Weld it too.
flanders's Avatar
No problem welding it, just make sure it's perfectly clean from any oil or dirt.
Here is my temp bung.
Old 03-17-2018, 08:32 PM
s2000Junky's Avatar
You can do a lot of crazy things in this world, and then deal with the consequences.
Old 03-17-2018, 08:54 PM
If it works, and is simple, it is not crazy.
Old 03-17-2018, 10:23 PM
s2000Junky's Avatar
Ahh no, i wouldn't trust JB weld on containing a fitting/oil to save my life. It might work in a pinch if you had to as a very temporary solution, but yeah your crazy to suggest it as anything else.
Chibo
06-11-2020 08:18 PM
s2kbtos
03-14-2013 09:39 PM
s2kpotenxixe
11-26-2012 02:19 AM
lotus7racer
01-23-2008 09:42 AM
Quick Reply: Is the oil plan weldable?
