Oil Seepage on valve cover & around spark plugs
Do you guys know what the problem is here, given the pictures? Any insight would help!
Looks like a little oil is getting around my spark plugs too.
This is the front most bolt on the valve cover, just in front of cylinder 1.
Look around the nuts... a little oil...
Thanks guys!
Thanks guys!
has your valve cover been removed before? looks like it was removed and installed w/o installing new valve cover/bolt/spark plug seals. if that's all it is, should be a easy & cheap fix. it's usually recommended to replace those rubber seals every time the valve cover is removed.
^ I agree. I had this problem with my tC and the gasket was bad and oil came up into the spark plug cylinder. Anyways on the s2000 you would need a gasket kit for the valve cover and gaskets are seperate for the spark plugs. But that's what I would check.
Awesome. Thanks!!! I've searched online for replacement seals but couldn't find any. Is there anywhere else to get them besides the dealer?
Appreciate the help! I love S2Ki.
Originally Posted by Nick.,Jun 7 2009, 09:17 PM
how many miles on the car? pcv valve changed?
To be honest, I'm not entirely sure how many miles the engine has on it. "Not Actual Mileage" title -- if I had to put a number on it, based on the carfax I would say 40k.
