Oil sump -> Clutch Housing Torque Specs?
Hey folks, I was wondering if anyone could point me at the torque specs for the 14mm bolts used to connect the sump to the clutch housing?
I've checked the Torque Specs thread, but I wanted to double check which values I should be looking for; I've guessed that it's:
Because I couldn't see anything closer. Any advice appreciated!
Transmission Bellhousing Bolts (lower small x 2) - 33
Transmission Bellhousing Bolts (lower large x 2) - 47
