Over reved it
Over reved it
hi guys I probably over reved my ap1 to about 10500 rpm for a split second went into 2nd going about 72mph I have the upgraded ap2 retainer and the car seems to run ok no power loss or cel should I assume I am fine and just be more careful next time?
Somehow, I don't find this surprising at all.
You either screwed the pooch or you didn't.
How did it feel and sound immediately after that?
Ap2 retainers will surely save you.
They raise the retainer split RPM (9700) over the valve contact RPM (10700)
The engine will be able to withstand a higher money shift.
Hit 10k in a stock AP1, split the retainers.
hit 10k in an AP1 with AP2 retainers, you will not split the retainers.
I pulled an amateur move and did the same thing last summer , although I had redlined 3rd going for 4th and grabbed 2nd by mistake and the car felt like I hit the brakes and immediately was either bouncing from the limiter or valve float. So your guess is as good as mine on what kind of mechanical rev I hit. It was a bad one! The engine felt fine though and have had no signs of belt valves with how it runs etc. Ive put 2k miles on it since then so I appear to have dodged the bullet on this one.
This. If your valves made contact this will let you know. I would rather know and have the ability to pull the head and replace one or two, then let it break, drop and mess up my pistons and cylinder wall.
