P0136 & P0137 bank 1 sensor 2 heater circuit low voltage
After installing a headerback Berk exhaust with a test pipe, I started getting these two codes and have been tearing my hair out trying to get rid of them. I've tried
*checking the wiring of my secondary O2 sensor to make sure nothing was pinched or broken
*replacing the donut gasket between the header and exhaust
*adding spacers and spark plug defoulers to move the sensor farther away from exhaust gasses
*replacing the O2 sensor with a new Walker unit from AutoZone
all without any success. I saw a couple old threads on here with similar issues but none of them posted any solutions. Anybody on here run into this and found a solution?
You might need a scanner that will give live data to get a view of the voltage to the sensor, should not be too hard to find the issue with the right tools. Good luck.
Yeah, I reset the ECU by pulling the backup fuse but the it just throws the code again after a few driving cycles. I just ordered a code reader so I'm gonna take a look at what the sensors voltage readings are like and see if I can find anything.
