P0411 code help, K&N FIPK
Assuming this is because the FIPK i installed since it is a air leak P0411 I'm gonna post some pictures if anyone can tell me if any of the air lines are hooked up wrong I'll be in your debt thanks
Do a quick search for P0411 and you'll see a ton of posts. You'll want to look at the manual diagram. If any of your hoses are not plugged in or the check valve is plugged in the wrong direction you'll get this code.
