P2646 CEL and It just won't go away!
like the title states I keep getting the P2646 code. I can't figure what is wrong. I have cleaned the screen for the VTEC solenoid. Didn't fix it. Oil levels are good and oil weight is correct. I am unsure on what to try anymore. Any help will be appreciated.
P.S I have searched this Forum and and no valid answers provided. |
Added information. It seems like it happens right before VTEC engages or slightly before. **Sometimes it will be fine**
Any more information on the car? Are you running the stock ECU?
I will check the switch.
The car is tuned on FlashPro. |
At the link above describes this is related to the VTEC rocker arms and cams. Could be electrical or oil pressure related.
Who tuned your car? Where does VTEC engage? 10W-30 oil? Reset the car to stock tune and VTEC engagement, reset the CEL, drive the car for a while and see if the code stays away. -- Chuck |
The car was tuned by UMS in Phoenix.
The engine is built, and turbocharged with supporting mods. I believe VTEC engages at 43k rpm ~( I don't remember exactly) |
Additional information*
The pressure switch has an elbow on it or else it would rub on the turbo's hot side. I never had any issues until after the motor got built. |
Photo may help. Thanks!
