passanger door wont go up
Old 02-21-2018, 10:24 AM
elkdaddy's Avatar
Default passanger door wont go up
my window wont go up but click when i press down
Old 02-21-2018, 11:52 AM
hoobastnk90's Avatar
window motor regulator probably
Old 02-21-2018, 03:25 PM
Car Analogy's Avatar
Received 1,315 Likes on 993 Posts
Its not just the passenger window disable switch is it? I'm imagining scenraio whete window was put down, then disable switch accidentally thrown, now it won't go up (or down, but you can't tell it won't go down because its already all the way down).
Disable switch oddly disables both passwnger side window switch as well as drivers control of passenger side.
Old 02-21-2018, 04:44 PM
windhund116's Avatar
Received 1,424 Likes on 954 Posts
That is odd. Never noticed it before.
Old 02-21-2018, 04:45 PM
alSpeed2k's Avatar
Window switch is the first thing that should be looked at. I've seen it happen a few times to new owners.
Old 02-22-2018, 11:01 AM
plizzat's Avatar
I have the same problem but mine is stuck up. Where is the window switch?
Old 02-22-2018, 06:06 PM
Drivers side, right by the drivers window up/down switch.
Old 02-22-2018, 06:10 PM
elkdaddy's Avatar
no becauce i made sure the disable wasnt on hence it makes a noise when i press down to futhwe clarify actually i hooked a miltimeter up and i get power when i press down but when i press up i get no power via multimeter also the only way i got it to go back UP was by running some wires from the battery to switch
Chris Kimball
12-14-2016 10:02 AM
plizzat
08-10-2015 03:49 PM
dylanrush
11-12-2013 06:40 AM
jammer2209
03-15-2011 12:49 AM
mikdys
05-09-2008 08:43 AM
Quick Reply: passanger door wont go up
