Passenger rear camber adjustment issue
I would venture to guess the angle angle of the impact is probably a determining factor since my impact caused my wheel to get bent backwards (toe) vs a curb where it would be more up & down. (Camber)
Not only was I speaking from personal experience on my s2000 when I hit a guard rail, but also from running my own repair shop.
So when the rest of the car is still fine, you maybe hit a curb and don't know if something happened, it would usually be the knuckle then.
The toe arm is tubular steel.
The LCA is cast iron.
The positioning and geometry of those two components makes them WAY less likely to bend than the knuckle/spindle.
The subframe tabs are stamped steel...but...again, the spindle bends first.
Thanks everyone for the reply's. He was definitely turning it the right way. I went to the shop and tried adjusting it myself and no luck. There must be something bent. I swapped out the coilovers that came with it for some OEM shocks off ebay and Eibach springs prior to the alignment. I'm going to reinstall the coilover in place of the strut assembly with the same ride height to see if the camber changes. That should rule out or confirm the strut as the issue. After that i guess it would be the lower or upper A arm or toe arm. I'm not sure how to test those without buying new ones.
james0933
08-18-2014 03:12 PM
