vinom |
09-14-2018 08:45 AM |
Pedal is sticky at start?
Hi guys, I have googled my issue but I can't seem to find a clear solution. So first off I have an 08 92000 miles. So long story short my clutch pedal is perfect, given I did replace/regreased the slave cylinder which took care of some squeaking. BUT I was hoping in replacing the slave that it would take care of the friction/"sticky point I have when I press on my clutch pedal. You see its not that it stick mid-way, or at the bottom, it sticks where right at the initial point. Like it feels almost like maybe there's not enough grease or something on the pedal, not sure if I am explaining correctly. This doesn't happen much at low RPM's but it seems to happen a lot when I am at high speeds and shifting to the next gear. After I push the pedal past this friction point its perfect, bounces back fine and car shifts good. Any ideas?! Do I need to replace master cylinder? Thanks!!
