Picture of Serpentine Belt for A/C Delete.
- I've been unable to find this on google or the service manual but will someone please post a picture or diagram of the accessory/serpentine belt installed in a car with A/C delete.
Standard diagram. He just deleted -- fuzzed out -- the AC from the drawing. Doesn't answer the question, of course, but the AC was "deleted."
Simple Google shows the "AC Delete" belt is 31110-PCX-505 (replaces 31110-PCX-G01). How it fits I've no clue but the right belt is the starting point.
-- Chuck
-- Chuck
Seems like you'd still need the A/C pulley, in order to keep the belt "sided-ness" correct.
I have my AC deleted. You just use the shorter S2000CR A/C delete belt size since the A/C compressor and pulley is effectively gone...and the routing of the belt is identical otherwise
so the pic above says it all.
Yep, used the shorter CR belt when my ac clutch took a dump on my ‘06. Routing is the same, minus the AC pulley.
