PLS HELP! 05 cranks but wont start
Need help or advice 05 s2000 cranks but won't start (everything is stock on the car)
-New oem plugs/ pregapped at .043 (PFR7G11S)
-all fuses are good at both fuse boxes
-battery is good but also have jump box on it
-immobilizer works with key (green light turns off)
-fuel pump primes can also see my plugs were wet with fuel
-Cam and crank sensor clipped in good
-No CELs
What was done before the issue
-valve cover removed to clean and powder coat which means cam sensors were removed as well so its possible left and right sensor may have swapped sides (if that matters)
- valve cover gasket replaced as well
-after installation everything turned on and ran fine. Next day car would crank but wouldnt start..and now were here
-No CELs
First off, how was opd paint removed for powder coat? If it was media blasted, immediately remove cover, and hang on wall as decoration. If left in place it will destroy your motor. Its impossible to clean all the innards of blast material, it will get in your oil and motor will be toast. Hopefully the one day of use hasn't caused too many issues yet. Change oil and filter along with new cover.
Only use chemical stripper to remove paint from valve cover.
That out of the way, first thought just reading title was going to be cam or crank sensor. Since cam sensor was about the only thing touched that could cause this symptom, that is where to start. Only odd thing is it did run ok at first.
Ok thats what i thought couldnt see a difference when both were removed. But no media blast was done. CEL does work but nothing showed when i put a scanner to it
I also checked the ground (G101) on the back of the head the best that i could and it looks to be intact but i think i will remove the VC and check again. Does it have to be grounded to that exact bolt?
So you got spark (hopefully with correct timing as well) and fuel, the only other thing that's needed besides that is compression.
Seems very unlikely that you lost that over night but since there isn't that much else to check you might as well do a compression test.
...which for a non staet condition, you don't need an actual gauge or actual numerical compression numbers. Just your finger on plug hole, make sure compression pushes it away forcefully.
Not sure if you can get a finger down there though on our motors...
So you do the reverse, put hand over spark plug tube then send the piston down. If it sucks in your hand and it stays sucked in, then compression is good enough for combustion
